Tel-Elmar 135 and the M8?
johnastovall
Light Hunter - RIP 2010
3:39 AM
Dublin, Texas, U.S.A.
I know some people are using them on the M8. I got one last night just because they seem so cheap and the optical quality seems very hight. I know Puts compares them to the Zeiss 135/4 Planar which was wonderful lens on my Conterex system.
I assume it'll bring up the 90mm frame lines. I'm not planing on coding it but will stick a cut filter on it but most likely just a B+W.
Anyone playing with the 135's?
The 135 Tele-Elmar (f/4) brings up the 24+35 frames on the M8. If you press in the lens lock release and turn the lens as far as it'll go, then you can get the 90 frames to show (thank Jaapv for that trick) and then guage the framing about halfway between that and the rangefinder rectangle. I have an off-brand zoom finder that actually has a 180mm setting which is what I use. Or you could buy a 135mm finder, which are easy to find, and mask it off. Or you could buy a 16464 short focusing mount and use the 135's lens head on a Visoflex III (I do that sometimes too).
As to the lens, there's nothing bad you can say about it. Using the aforementioned short mount, plus a 14167 M/Viso-to-Leica R mount, it can be used on any Leica reflex, and plus a Leica R-to-EOS adaptor can be used on any Canon EOS DSLR. I use mine on my 20D that way.
I 've gotten an ELCAN III generation which does not allow the lens cell to be removed for use on the visoflex as the earlier ones did. It also has the built in hood.
