The Industar 50 is here!
Gordon Coale
12:31 PM
My collapsible Industar 50 has arrived. It's a little jewel! I will have pictures of the lens up in a day or two. Pictures through the lens a little later.
Two questions. Setting the aperture is very stiff. Any easy solutions? And the infinity lock on the tab is digging in to the vulcanite a little bit. Will a little grinding on the offending screw provide enough clearance?
Which camera body are you using? The Fed-2? I've never had a problem with the infinity lock digging in on a body.
I've got 3 I-50's.Allof the aperture seting tabs are somewhat loose. better al ttle tight than too loose. At least it will stay put.
-Paul
Try a drop of lighter fluid (rosonol). I came across tis tip on a website but can't find it. It worked with my lens.
Jay Javier has it on his site. Just where do I put the lighter fluid? At the base of the rotating f stop ring? I wasn't clear on that part.
I second the use of "Try a drop of lighter fluid (rosonol)."
I went with the lens on a photo shot before trying it at home and found it was very stiff. I went into a small market and got some lighter fluid, I think it will be a life time supply, and I put it on the base i think. I don't have the lens in front of me but it seemed logical.
It worked well. The lens movement was better and still works very well.
Leo
Here is the Industar 50. I think I solved the problem with the tab digging into the vulcanite when it is in the infinity stop. I just received Joe's old FED-2 with the film advance problem. I noticed that the lens flange on Joe's old FED was sitting higher from the vulcanite than on mine. I removed the lens flange on mine and discovered there were no shims. It was measuring short and now I know why. I put the shims from Joe's FED on mine and no more digging into the vulcanite! A short term solution. I need to get some more accurate measurents and make some shims.
The Industar-50 is a great little lens. Not bad for $17 plus shipping. The lens flange to film plane is off on the FEDs I used it on so there is a little focus problem but I'm working on that. In spite of that, this shot wasn't too bad. I'm really looking foward to getting the adjustments done because this is a wonderful lens!
Gordon you are sounding like a proud father, but understandibly so. enjoy the lens. I have the same set up, and its a total pleasure to use. I completed it with a Leningrad 4 meter which works really well. Best
John.
Gordon, indeed that's a really nice looking set up and makes me think my Fed-2 needs one of those as well. Looking forward to see more from it !
Albest,
Oscar
