efix
RF user by conviction
Hello all, I need your help!
Since recently I've (re-)developed a love for film, and would like to add a film M to my M8. Since I'm a bit on a budget, I can't just walk into a store and buy the next-best used M6 -- let alone an MP or M7. So here's what's on my list so far:
Second favourite would be the M2, because it's a "real" M, and I like the idea of using an all-mechanical camera with a little help from an external meter. Downside: Would stretch my budget a bit.
From a rational point of view, the CL would be all I need. It would have a meter, yet mechanical shutter and fully manual operation, and it has 50mm framelines I need for my 50 Planar ZM.
So ... which way to go? Which one would you recommend, also in terms of reliability and logevity? Will a CLE work (or be serviceable) in ten years from now? Would I be happy using the CLE's 40mm framelines with a 50? (I asked this before and even looked at a schematic of the CLE's framelines -- not sure still.) Is a CL easier to operate than an M2? (In terms of loading and rewinding the film, access to the shutter speed dial, size etc.) Will I have a hard time finding batteries for the CL? And top of all -- what to look out for when buying used (not from a dealer)?
Thanks so much in advance!
- M2 (knob or lever doesn't matter -- or does it), can be had from 400 € up. I'd be perfectly happy with all-manual all-mechanical operation using a hand-held or hot-shoe-mounted light meter. What to be aware of?
- CL, can be had for anything from 200 € up. Would feature a built-in light meter, granted I could find one that works. What to be aware of?
- CLE, can also be had for anything from 200 € up. Features state-of-the-art 80ies light metering, auto exposure, and I love its the 80ies design. Downside: electronics could eventually stop working and render the camera useless. Also, no built-in 50mm framelines.
Kherberos
Laurent
I saw a M4 in really nice condition in Paris few weeks ago for 420 euros. So a M4 could be nice also, and newer so it may be easiest to find one in nice condition.
I f you are not in hurry, why not saving patiently a bit more cash, then go for a M3 or M6?
But I have this impression that used M camera bodies are getting more expensive than half a year back. It has been months now since I saw a M6 for around 600 euros.
sc_rufctr
Leica nuts
M2 all the way but have you considered a Canadian M4-2 or M4-P?
I love my M3 and M4-P... But at a guess you wouldn't like the frame lines in an M3.
Buy the best camera you can afford. Any saving on a "bargain" camera may soon be chewed up in repair costs.
Keith
I wouldn't personally ever have a CL over an M2 ... the M2 is a joy to shoot and makes the CL feel like a clacky toy.
Out of the options you've mentioned the M2 is an absolute no brainer IMO.
maddoc
... likes film again.
Most practical tip, I would buy the M4-2 in the classifieds here and be done (no connection to the seller).
The CL is nice and compact but many suffer from low contrast RF patch (deterioration of the aluminum coatings) and defect CdS cells or mechanics. Focus is OK with a 40/2.0 or 90/4.0 and maybe with a 50/2.0 also (but critical close focus). The CLE is much newer and handles nicely but I don`t know who can service it once the camera is broken. Lots of electronics.
shiro_kuro
Charles Bowen
"Is a CL easier to operate than an M2? (In terms of loading and rewinding the film, access to the shutter speed dial, size etc.) "
I never used an M2 but I am sure after you get used to it you would be fine . But if it is an issue perhaps an M4 .This my personal camera and I can assure you it does not disappoint .... or as Gabor suggested the M4-2
Good luck with your decision
SimonSawSunlight
Simon Fabel
M2s can be had for less than 400€ and are probably a better long-term investment than a CLE.
efix
Thanks for your suggestions so far!
Kherberos -- saving up is not an option, as I know I'd be spending the money on something else first ... ;-)
M4, M4-2, M4-P -- yes, i actually considered these, they seem to be very good as well, although I'd prefer the classic look of the M2, and I won't need 28 or 135 mm framelines. Also, going prices seem to be higher for M4s than for M2s.
efix
Hmm, that's what I thought. Thanks!
SimonSawSunlight
Simon Fabel
oh and it's funny, but M4-2s and M4-Ps are usually more expensive than M4s here in germany, at least they were when I was looking for my first M.
alexnotalex
M2 for sure from your options. You have all the electronics you want with the M8 and the feel of the old M bodies is very special.
Consider an M3 for the bigger VF and base length for that ZM Planar... at least take a look through the VFs and compare. Although the M2 VF magnification is the same as the M8 if I recall, so you might be happiest with that.
They are all a good choice, go with what makes you smile biggest.
Alex
Alex
siracusa
I second Kherberos' suggestion of saving and getting the best body you can. I have M2, M3 and M4-P bodies, and recently sold a CL. CL didn't wow me (and at times I noticed its less accurate focusing). M2 is my favourite - refined, run in, comfortable. But I use M4-P most: just practical. I therefore second the suggestion to consider M4-2 or M4-P. If you can't live without metering, how about M5? (or Hexar, or Bessa...). Don't worry too much about the more elaborate CLE meter: can achieve same result with a properly used old Weston Master. Key questions are probably what feels best to you from a user perspective, and can you live without built in metering. I can, so I sold my CL which I rarely used.
Archiver
I believe that the outstanding documentary photographer Mary Ellen Mark refers to the M4-P as 'a very special camera'. I've seen photos of her with two such cameras around her neck.
Ronny
The M2 - No doubt!
I would buy a Bessa r2a or r2m before a CL or CLE. But that is just me.
Kherberos
Laurent
I understand very well this pathology… this why I opted for an "à la carte" MP, and a leasing plan, 4 weeks ago
This way, I don't have to save, just to pay each month during the next 18 months
maddoc
The M4-P !? Great !
rogerzilla
M3 unless you use a 35mm lens more than a 50mm.The M3 is built for the 50mm. You have three options for using a 35mm on an M3 anyway:
1. Accessory VF, fine for occasional use
2. Buy a 35mm lens with the "goggles"
3. Just wing it; the whole M3 viewfinder (ignoring the framelines) is near-as-dammit a 35mm field of view and this method is at least as accurate as the viewfinder of an LTM body!
thegman
If you're shooting B&W or C41, then maybe meterless is OK. If you want to shoot slides, then I'd really want a meter. For your budget, I'd be thinking Bessa, or stretch it a touch and get the very awesome Zeiss Ikon.
efix
I understand very well this pathology… this why I opted for an "à la carte" MP, and a leasing plan, 4 weeks ago.
This way, I don't have to save, just to pay each month during the next 18 months![]()
This is what I did to "finance" my M8 --still paying back to our savings each month
