The Ryme of the Ancient Photographer
bmattock
4:37 PM
Detroit Area
If you read this - please reserve your judgement until the end, there's a point to this and it isn't to make anyone angry:
Some caustic die-hards insist that the digital camera isn't a camera; it is, they say, a cult. It is true that a lot of fanatical nonsense has been perpetrated in the name of 'digital' photography, but anything capable of arousing such ardent, almost passionate partisanship (and opposition) must have something.
The digital camera has plenty.
Generally, the digital camera is an offspring of the manufacturing industry, for it was designed to make use of the relatively inexpensive and good CMOS sensor created for professional manufacturing work. On this basis, design proceeded. As the work went on, other advantages began to appear. In a compact little camera, a memory card capable of holding hundreds of images, each 6 to 12 megabytes in size, could be loaded. By using a small, short-focus lens, depth of field at any aperture was excellent. Even with fast lenses, lenses rated at f/2 or thereabouts, depth of field remained excellent.
So the digital camera with the relatively fast lens appeared. And because its early converts used it primarily in news work, and obtained remarkable, unposed pictures of celebrities, it became known as a 'candid' camera. And that "tag" nearly proved fatal to the digital camera, for people soon grew disgusted with the vulgarity, the lack of good taste which flourished in the name of digital photography.
The digital camera was rescued from the doom toward which it was headed by the discovery, on the part of serious workers, that it had many really useful and important possibilities. Given precision camera construction and intelligent post-shot processing work, digital photography had a lot to offer. The digital camera could be fitted with accessory lenses for wide-angle or telephoto shots, thereby giving its operator an immense optical change of pace and control. It could be used for serious portraiture as well as news; it could cover sports easily and compactly; it could be used under otherwise "impossible" conditions.
...BEFORE YOU EXPLODE WITH RAGE...
If you have read this far, you're probably wondering what the heck this is all about.
It's not a joke, but a jest of a sort. This treatise was written not by me, but by Thomas H. Miller and Wyatt Brummitt, for the book "This is Photography," which was published in 1945 by Garden City Publishing Co., Inc. Of course it did not refer to digital cameras - where I have written 'digital', please insert the word 'miniature' in its place. Where I said 'CMOS' or 'memory chip', please substitute 'film' and 'roll of film' - 'manufacturing' was actually 'motion picture' and so on like that. Photoshop becomes the darkroom. I'm sure you see where I'm going with this. It didn't change the tone of the debate, just the terms used to substitute film for digital. A sort of a 'Mad-Lib' for those of you who remember them. I did this to illustrate a point.
In 1945, WWII was just about to end or had just ended for many nations. Amateur and professional photographers were returning to looking forward to having access to supplies that had been restricted or unavailable, like flash bulbs, film, and of course, new cameras and technology advances. The so-called 'miniature' camera (35mm rangefinders) was all the rage - and the 'old-timers' who insisted that it was just a toy, a passing fad, a joke, were raising heck about it. This was a response to those who still felt that a 35mm camera was not a 'serious' camera, and certainly was not to be used by a 'serious' photographer.
You might note the irony - except for the words 'digital' and 'miniature', the arguments are largely the same. It's not good enough, it's a fad, it takes control away from the photographer, it 'doesn't look good' and so on. Yes, even the recently-heard "Digital is too flat and has no dimensionality for me" was used back then (only regarding 35mm film, of course). None of this is new!
History will note how things ended up.
A word to the wise; history has a tendency to repeat itself.
It can also be said that MF is still alive and kicking - but the debate over whether 35mm is a 'toy' or a 'cult' or a reasonable replacement for MOST (not all) of the things MF does is long over. Extract from this what logical prediction for the future that you wish.
And that's it for my April Fool's special. I went out and shot both digital and 35mm film today. Enjoyed both of them. Didn't want to choose - didn't have to.
Best Regards,
Bill Mattocks
Wayne R. Scott said:
Bill,
On a serious note, what camera are you shooting for digital and how is your work flow with it?
Wayne
Pentax *ist DS - chose it because of backward capability with K mount and M42 lenses, but also use it with digital-only zooms in standard ranges. Workflow is great for me - but then, I don't struggle with Photoshop (actually The Gimp) too much, so I don't have to spend hours with an image to get what I want. Also, being color-blind, the digital does a better job of preserving the actual colors - scanned color film sometimes does not, and I can't put it back once it is gone - because it 'looks right to me' when faces are purple, etc. That's why I prefer my film to be B&W. So to answer your question - for making money, the DSLR is my only real option, a real blessing.
Best Regards,
Bill Mattocks
Unfortunately, they don't teach that anymore; too "controversial". It's best to keep on buying stuff on the bleeding technological edge that will become obsolete in half a year and keep the economy humming. Whoops, did I say the "o" word? 😱
I say leave it to history. 1984 was nothing like 1984.
"Like one that on a lonesome road doth walk in fear and dread,
And having once turned round walks on and turns no more his head,
Because he knows a frightful fiend doth close behind him tread".
I closed my lids, and kept them close
And the balls like pulses beat
For the sky and the sea
and the sea and the sky
why oh why this horse
won't die when to a pulp we've beat?
I think that as digital photography progresses, and they are already getting quite cheap, more niche markets will emerge and maybe some company live Voigtlander or some entrepreneur in China will satisfy our needs. I will wait until then. Hopefully the answer will come in the shape of an inexpensive Bessa or maybe something that looks like a Cannonet!
Psalm (ISO)23
Analogue is my shepherd, I shall not want,
It inspirest me to lay down great prints,
It restoreth my vision:
and leadeth me in the path of archivability for silver's sake,
Yea, though I walk through the valley of the shadow of digital,
I will fear no pixel:
For thou art with me, thy grain and thy tone they comfort me,
Thou preparest a darkroom before me in the presence of the digiheads:
Thou anointest my negs with Rodinal, my tank turneth over.
Surely contrast and sharpness shall be with me all the days of my life:
and I will dwell in the darkroom of analogue forever.
Albumen.
© Andy K 2006
I also use a Pentax *ist-DS and a pair of Sigma zooms for my "professional" real estate pictures. Anyone who would like to see the pictures I post on our web site can visit http://www.billandcarolphelps.com. Go to "Homes for Sale" and click on one of the thumbnails. For interior pictures I use a Vivitar 285HV and 99% of the time I bounce it from the ceiling.
Bill's analogy is, IMO, dead accurate. The digital camera is here to stay and film camera makers will simply have to adapt to a smaller market. The demand for the old classic cameras hasn't stopped so film will be around for many a year yet.
As for the miniature camera surviving, having read the 1930's publications such as "Minicam" - my father had stacks of 1930's photo magazines - I think any question of the camera's viability and continued life was the continuation of pre-war debates. The question had been settled long before 1945 but the arguments continued. It's also possible that the authors of the book were simply giving some background about the cameras and how they evolved. Still, it's interesting how the arguments don't really change from one generation to the next.
One of the first things the Allies did in Germany following the cessation of hostilities was to get Leitz and other companies producing consumer goods to ramp up production as quickly as possible. Anything to generate hard currency and the Leica IIIc was perfect for export to a camera-starved United States, England etc. The large numbers of IIIc Leicas produced between the end of the war and into the early 1950's attest to the demand for the miniature cameras. Had Zeiss not been in the Soviet Sector, I feel confident that the Leica would have had competition from the Contax.
Bill, that's both interesting and amusing. I'm glad you posted it.
Walker
