This helps me determine what type film in camera
Bill Clark
6:42 AM
This maybe moved if not in correct subject head.
I've used different methods to determine what film I have in my camera. Reason, many times I will have different films in each camera and use based on conditions and what I want to accomplish. With Leica some have the circular piece but that tells speed not type of film such as Pan F Plus or Delta 100 and so on.
To help me remember what film I have in my camera I now use Post it Notes page markers. I write the type of film in the camera, using a sharpie pen then either putting it on the base plate or the bottom of the case the camera is in. They fit with no overlap.
Thought I would mention it here to help.
Here is a plsce to buy them:
http://www.amazon.com/Post--Assorte...eywords=post it dispenser&tag=viglink22207-20
Since I carry an Iphone with me I make a note when I load a certain film in what camera. When I complete the roll I just delete the note. Helps me to remember.
I put a small piece of masking tape on the top of the film can with the film ID on it, and transfer it to the top of the camera when I change film. In the vein of taping your camera from another running thread, I cover the "Leica" with the film ID tag. :)
Thanks.
So far I like the Post It Note as I can use a Sharpie and write on the note before I put it on my camera.
All good ideas to help.
i use a small square cut from the end of the film box in my hot shoe or a square of thin cardboard with the type written on it in the hot shoe.
If you're using a flash or shoe mounted meter then colored dots from the office supply work. Use green for one kind of film, red for another and so on. Make a card with the various color dots and indicate on it the type of film.
I like the blue 3M painters tape. I buy 2" width roll of tape which I use when I re-load my film cassettes. The width works for me to get on to the film and wrap around the cassette on to the under side of the film. I cut off about a 1 inch piece for each roll and it works for me. When I load the film on to the dveloping reel, taking the tape off leaves no residue.
