Time lapse photography Remote for NEX 5
10:40 AM
Hi!
Wondering how you can do time-lapsed photography on the NEX 5?
Behold TempusNEX Remote Time-Lapse! :)
VIDEO: http://www.youtube.com/v/okfSp9d_mps?fs=1&amp
I wanted to be easy to use!
No need to open case to change settings.
Specs:
-10 METER RANGE!
-ON/OFF switch in the back;
-MODE press-button to choose mode;
-a potentiometer dial knob for choosing lenght of time in each mode;
-an IR led for emitting signals
-and a blue LED for visual feedback of operations.
You got 4 modes:
Quick mode: - this is the fastest way of getting it going.
- just press the MODE button before switching it ON.
- turn the remote ON without releasing the mode button. The time you keep the mode button pressed, is the time you want between the shots!
- Release mode button. You now have got 4 seconds of quick flashing LED for placing the remote pointing the camera, and get out of the frame, before time lapsed photography starts.
MODE 1: - 1 to 10 seconds delay.
- Switch the remote ON.
- rotate the dial knob choosing the value of time-lapsed delay: 1 to 10 seconds on this mode.
- press the mode button ONCE. The LED will falsh once, to show you have selected MODE 1. You now have got 4 seconds of quick flashing LED for placing the remote pointing the camera, and get out of the frame, before time lapsed photography starts.
MODE 2: - 10 to 60 seconds delay.
- same as above, just press MODE button 2 times, and LED will flash 2 times showing you MODE 2 is selected.
MODE 3: - 1 to 30 minutes delay.
- same as above, just press MODE button 3 times, and LED will flash 3 times showing you MODE 3 is selected.
It works with 2xCR2025 INCLUDED.
Its firmware upgradable.
THAT'S IT!
Inicial Launching Price: 69 USD
I'm also working on a mechanical version (with a servo arm) for the NEX3 now (or any other camera with no IR).
And I will do IR remote versions for Canon an Nikon cameras too.
(or custom ones you may prefer)
Pre-order now: tempus@bymac.org
Check the site: http://tempus.bymac.org
