Tips for disposal
Whateverist
12:46 AM
Up until now I've been collecting used developer in glass bottles that were headed for disposal anyway and handing them in at the local recycling center's post for chemicals. However, I'm fast running our of disposable glass bottles, and I'm not starting a drinking habit just to keep the supply of empty liquor bottles going.
How do you store and dispose of your chemicals? Can they be safely stored in plastic bottles? Am I better off with small bottles or do I spring for a gallon or bigger jug?
You could try a science supplier? I purchased ten 1-litre plastic bottles to use as chemical storage several years back for practically nothing.
~S
I use one shot developer and it goes straight down the toilet ! I understood that in the small quantities, 600 ml of solution @ 50:1 max , it was OK.
Most developers can be disposed of via local waste water systems if diluted with lots of running water. (Caveat-I'm not a chemist nor do I play one on television. I'm going on what I've read on other boards.)
From what I know, fixer is the real problem, due to the potential high levels of dissolved silver/silver salts in the liquid. Silver is antibacterial and, in large quantities, can damage the bacterial balance that makes most waste water systems work. I don't know what that quantity is.
Directly to your questions, yes, plastic bottles should work for short/long-term storage of chemicals. Even used milk jugs of various sizes should be alright. Most of the chemicals we use in the darkroom aren't that corrosive that they would eat through a plastic bottle. My only concern would be how secure is the top? You probably want a top that can be tightly secured in place to prevent leakage/spillage during transport to the disposal site.
Most developing chemicals can safely go down the drain. I pour all of mine down the drain,, Only a few seldom used chemicals should be disposed of by turning them in..
The quantity that can safely be poured down the drain is rather high. I worked for a photo processing service for years and we poured large quantities out and the city waste service was OK with it
The chemicals we used were B&W and color film and paper developing chemicals..
I store my Kodak Fixer in a Arizona Iced Tea plastic bottle...the bottle is thicker than your normal milk or juice bottles...I keep it in a dark closet and have never had a problem with fixer going bad other than getting used & old...
Here in Europe it goes in the chemical disposal box. 50% of all modern developers you can put into the drain. Stop too, only the fixer and some toners (Selenium) you have to collect.
spent fixer goes into empty wiper fluid bottles which are eventual taken to a waste management facility for proper disposal.
Everything simply goes down the drain since I'm not processing industrial quantities with tons of waste ;)
Somewhere I've once read the statements of a chemist, even normal non-industrial quantities of used fixer are completly safe down the drain.
Don't know where you live but here is a thought:
To help, suggest if your waste is connected, call the processing facility for sewer and ask what they recommend. With pollution laws in place now, the processing plants take out many chemicals before discharge. Ask how many gallons go through the plant and I think you'll be surprised at the volume of sewage that is processed each day.
