JoeV
Thin Air, Bright Sun
Just a reminder: now that the weather here in the northern hemisphere is getting more spring or summer-like (depending on your lattitude), it's time to 'summerize' your Retina and go sans the carrying case (if you have one). I did this to my IIIC yesterday, and it makes carrying the camera a bit easier due to the reduced size; I also relocated the metal carrying chain to the camera's corner mounting lugs.
BTW, yesterday I finished processing a roll of Ilford HP5 shot over the course of several weeks. But I knew that I had mistakenly over-exposed some frames, due to thinking I had FP4+ instead. So, I used HC-110 at a dilution of 1:100, developed for 15 minutes semi-stand. Nice results, I'll have to post a few shots soon.
~Joe
~Joe
bkrystad
Good idea, more light = fewer excuses!
I'm scratching my head a little bit about my II (011 model), which has no strap lugs on the body. It came with the ER case, but I don't like handling the camera that way. So that leaves me holding it securely but not forcefully, and gambling that I won't be a dope for once and drop it.
Anyone dealt with this before? Options for straps only on cameras with no lugs?
mcgrattan
You can get straps that screw into the tripod mount.
