Muggins
Proprietor of Orphanage for Lost Cameras
I'm reaching the end of a brick of Tri-X 400 in 35mm, and I still haven't found a way of getting the blasted stuff to dry flat so that I can easily scan it. It air-dries in a warmish darkroom, but always dries with a bow across the width of the film, sometimes enough to make it almost unscannable whilst on a good day it just knackers my attempts to get images sharp. It helps not that the darkroom I use does not have a glass neg holder...
I've a large and weighty library, but several kilos of books doesn't seem to make the blindest bit of difference. Any other suggestions would be gratefully welcomed! Failing that, what do you use that will dry flat and be scannable?
Many thanks,
Adrian
Many thanks,
Adrian
