Tri-x 400TX pushed to 1600 in xtol (1+1) times
Flyfisher Tom
2:38 PM
If you've pushed Tri-X 400TX to 1600 in xtol (1+1), could you provide me with your preferred time/temp?
Not looking for official Kodak published times, already know them. Looking for something you've tested personally and been satisfied with.
Thanks so much for your insights.
regards
//edit: Here's some results from our site:
Recommendation:
http://www.rangefinderforum.com/forums/archive/index.php/t-5879.html
Search results:
http://www.google.ca/search?q=site:www.rangefinderforum.com+tri-x+xtol+1600
I did a search over at the "other" site (you know which one I mean), and there was a bunch of info. Most of the results indicated 1+2 rather than 1+1, but you can see for yourself.
One recommendation:
http://www.photo.net/bboard/q-and-a-fetch-msg?msg_id=00822n&tag=
The search results:
http://www.google.ca/search?q=site:www.photo.net+tri-x+xtol+1600
Sorry that I don't have any personal experience to chip in with. Hopefully someone else can help out...
BJ
P.S. A searching tip for everyone! If you're looking for info in the archives of a site, don't use the site's Search feature. I find that it often ignores all but the newest content, or is not sufficiently powerful enough. You can use Google (and maybe other search engines) with the "site:" keyword to find what you're looking for. For example:
site:www.rangefinderforum.com tri-x xtol 1600
Cheers!
For 400TX @ EI 1600 - I use The Massive Dev Chart and add 15% to the time. It works well with my Durst condenser enlarger. This is with a 1 minute pre-soak and single inversions of the tank at 1 minute intervals. All at 68 degrees fahrenheit.
