Truly Determing Left or Right Eye Dominance
RayPA
Ignore It (It'll go away)
7:35 PM
The GOLDEN State
The link below has a quick and easy test you can perform to determine if you are left or right eye dominate. The link is to an Archery site, so the follow-up advice has to do with using 'shooting sports'
Eye Dominance
It's fun. One member on the group where I picked this up discovered he wasn't using his dominate eye to photograph.
Confirms i'm left eye dominant. I discovered that one day when i realized i always raised the camera to my left eye and that make my nose hit the camera back or worse, the touch pad on my SLR's which skewed my focus point.
JCA
I watched some movie a long time ago involving Nicholas Cage as an Apache Helicopter pilot. As some of you may know, you get two different visual feeds with an Apache. So he had to break hish eye dominance so that he could accept an equal amount of data from both.
Following that, I decided to switch from right eye to left eye dominance. It is possible, actually. I am now in the process of trying to even if out. Just for fun.
allan
Here's a simple trick, if you wear glasses.
I've been through the right-handed, left-eye problem, because I used to shoot quite a bit, both with bows and shotguns, which have similar problems. The problem with shooting a shotgun, for example, where there is no rear sight, is that if you shoot right-handed, but your left eye is the master eye, you are looking slightly across the barrel at the target, rather than down the barrel. And you need to keep both eyes open for faster target acquisition.
Rather than trying to learn to shoot left handed, to match my left-eye tendency, I was shown a simple trick. Since you strive to make your shooting stance identical from shot to shot, you always look through the same place on your glasses. So the trick works like this: you mount the gun, take your right-handed stance, close your right eye, and then, with a pencil tip, figure out precisely where you're looking through your glasses with your left master eye. It will be a very small spot. With a shotgun, for example, it's usually the upper right quarter (with a bow, for me, it's usually left center, or slightly below center.) When you figure out that very small spot, you can put a tiny dab of Vaseline, or a very small piece of Scotch tape on that spot. When you then mount the gun, since you are looking for the target but can't see through that spot with your master left eye, your master eye will automatically shift to the right eye -- to the eye that can see the target. When I say a small piece of tape or some Vaseline, I mean SMALL. Smaller than a BB; more like the head of a straight pin. Since when you're just walking around, you look through the middle of your glasses, you're not even aware of the blind spot when you're not actually shooting.
I think this should work with cameras, too, if you tend not to look through the exact center of your glasses, but to cock your head a bit, to look at your target. With a little piece of tape, you should be able to force a master-eye switch.
I find with cameras, though, the problem is not as bad as with guns or bows, because you're looking down the tunnel of a viewfinder, and your eye/brain knows that. You should be able to shoot with either eye without too much problem; I suspect some people who think they are opposite-eyed actually are not, but simply have a stronger or clearer opposite eye, and so shoot with that by preference.
JC
Yeah, left-eye dominant but right-eyed shooter.
And as John says, as a right-hander this makes the other kind of shooting fun. I've been meaning to docor my specs like he describes for agaes, but haven't shot in a while...
Yup...I'm a Lefty. Have been shooting (with cameras) this way from the start.
I just thought that everyone shot this way, but then I would see someone using their right eye and would think them weird...now I know why...Thanks.
Hmmm. Since I'm almost legally blind in my right eye, but have 20-40 in the left eye, I had no choice but to use the left eye. I can't even focus a camera or compose a shot with my right eye...
Great exercise Ray! When I first started out in photography I used my left eye. Then one day, with no conscious thought to do so, I switched to using my right eye. And I have been using it ever since. Looks like there was good reason for my switch afterall. It appears that I am right eye dominant.
I would love to be able to use my right eye as the both eyes open technique definitely allows you to take the whole scene in when composing the shot. The vision in my right eye seems to be as good as my left but I'm dammed if I can get it to work the same way with the rangefinder patch and framelines ... I find them incredibly hard to make out!
Us left eye shooters just have to learn to deal with the oil off our noses sullying the backs of our cameras.
I guess when 'chimping' with a digital p/s it wouldn't matter a dam!
I must be a freak of nature.
Although I've long known that I'm right-eyed dominant, when shooting an SLR, I've always viewed through my left eye -- I just find it ergonomically more natural. However, when using a rangefinder, I use my right eye. Does anybody else switch eyes when using different types of cameras?
Long ago I was taught a similar test, using just a "thumbs up" with one thumb. Focus on a distant object, bring up your thumb to cover that object. You'll see two thumbs, but put the more solid one over that distant object. As in the online test, closing one eye will then reveal which is dominant.
I've always been left-eyed and right-handed, but when I had a cataract forming in my left eye and its vision deteriorated, I switched to my right eye. Now with that cataract dealt with I'm "ambi-eyed" but continue to use my right eye for the camera out of habit... plus that distance vision is a bit better in that eye.
