TX-1 and TX-2 service
qwilco
12:52 PM
I repair Hasselblad over 39 years and have also XPan parts and XPan 1 parts-list, I order parts from Hasselblad, for XPan and for TX, Fuji refuse any business outside Japan concerning TX. I am looking for parts-list XPan II or TX-2, I do not know why Hasselblad makes problems delivering this parts-list while they deliver any part to me.
Repairs on these cameras are most times the same, adjustment of distance metering, loosen screws from selector knob and more trouble loosen screws from trap hanging which need dismantling of finder system to lock the screws again.
I made a small alternative finder for the 30mm lens, it is a Voigtlander finder with top and bottom of the frontglass taped off with black tape for 4,5mm and the sides for 1mm, it have a spiritlevel visable through the finder in front for only horizantal use.
I also produce an adapter to use the PC-Nikkor 3,5/28mm on the XPan/TX as alternative for the expensive 30mm, this lens conver nearly the XPan negative size. On the adapter you can also use shorter lenses in the 35mm mode, for instance 20mm, with a 21mm Voigtlander finder in the shoe. etc.etc. If any college can help this old men with the parts-list for TX-2 or XPan II ??
Any TX question welcome.
