dermo
Hi there,
I think this has been discussed before but the thread is no longer available so I'll ask again -
Is the TX-2 30mm lens compatable with the Xpan 2?
I seem to remember something about the viewfinder not being compatable, but wanted to check here as I'm considering buying one.
thanks in advance,
dermo
thanks in advance,
dermo
S
Simon Larbalestier
Guest
Xpan 2 and TX 2 are the same camera as both were made by Fuji so the lens will fit and it comes with a separate viewfinder.
anglophone1
Same lens different [sort of] view finder, the xpan version is offset so it sits directly over the cameras VF, the TX version is centrally over the lens, otherwise the same and interchangeable [both fit in the hotshoe]
TX version doesn't come with center filter as part of kit either so quite an expensive add-on.
Clive
Clive
