kshapero
South Florida Man
Been thru this before but can't remember what to do. The film advance lever will not advance the film. It's just stuck. Anybody have a quick fix for this?
Nitroplait
Maybe fix it from under the button plate?: https://www.youtube.com/watch?v=K0ljbTWPl3M
helen.HH
To Light & Love ...
hmmm, I would be shooting in the meantime that Beauty Miss Leica
M-A ...
M-A ...
kshapero
South Florida Man
Oh...I am, but I don't want to ignore older siblings. They will be hurt.hmmm, I would be shooting in the meantime that Beauty Miss Leica
M-A ...![]()
Larry H-L
An old camera store trick, but use at your own risk:
Take off the lens. Rewind and take out the film.
Pick up the body and firmly smack down the base plate into the palm of your other hand a few times. Sometimes this will free it up. It has worked for me on both an FM2n and a Bessa. Good luck.
Bill Clark
Try pressing the rewind button and while holding it try advancing.
Steinberg2010
I would try this before you try the smacking trick. My FE had this issue and it was easily resolved with a screwdriver and moderately steady hands.
~S
Finglas
I had an Nikon FE for 28 years - never a problem.
Then my 2nd FM2n had this exact problem...
It's still stuck and none of usual treatments worked,
I recently got the name of a technician here in Dublin - will contact him someday when our tight Covid restrictions lift, as I'd like to continue with FM2n
Kai-san
Filmwaster
Is it really an FE in this video or is it an FE2? My FE looks nothing like it. Not a very good picture, but I think you can see the difference.
Nitroplait
It is an FE in the Video - He turns it around in the end. If you are confused look at this: https://filtergrade.com/jammed-shutter-fix-nikon-fe/
Kai-san
Filmwaster
Take a second look, the brass coloured plate in my FE is different and the bronze coloured arm next to it is missing from my FE. It's clearly different.
Nitroplait
I don't know what you expect me to say or see. The two examples I have given in this thread are FEs Tt is clearly visible when you see the top of the cameras.
And that is how mine looks.
I have no idea why yours would look different.
Kai-san
Filmwaster
Ok, so then we have established that Nikon made FEs with two different film winding mechanisms. Mine is serial no. 3220545.
kshapero
South Florida Man
Well not to worry, I have 2 other FE's in great working shape.
twvancamp
Thom
Does anyone in this thread have a recommendation for Nikon film SLR repair in the US?
hap
Redundancy at it's best.
Darthfeeble
But you can call me Steve
I have had good luck with a variety of cameras with Steve's Camera in Culver City California. stevecamera.com Note that the url is a singular steve.
Highway 61
Revisited
I confirm that some FE bodies will look like the one in this (now very famous) YouTube video while some FE bodies would look like Kai-san's FE. Which look like some FM cameras actually. Yes, Nikon changed their design at some point, which is not surprising : the FE production run lasted for seven years.I have no idea why yours would look different.
The FE (and FM) which look like Kai-san's camera cannot be fixed like the FE in the video. A friend of mine now has his FE stuck as well, same problem as kshapero's one and same design as Kai-san's one : none of the Internet tricks we could find out could solve the problem. The friend's FE had been sent to a repairman once already, for the same problem ; now the friend gives up and he uses another camera.
Kai-san
Filmwaster
That figures; mine is locked for the third time. I managed to fix it twice, but this time I'm lost. It seems to happen if I point the lens downward when firing the shutter. I originally bought the FE because it can use both AI and pre AI lenses. But now I've got a Nikkormat, an F, F3, F4 and FM3A, so I see no point in replacing the FE with another.
mconnealy
I got mine unstuck today with this suggestion from rodeo joe at Photonet:
George, have you tried pushing the auxiliary
shutter release? It's the little silver button recessed
into the camera base. It's there to be used by a
motor drive, but can be depressed with a biro point
or similar.
Also make sure the self timer isn't partly cocked.
or similar.
