unlikely but...
Comparing the physical size of both lenses?
The CV is the same size as the other classic Skopars and I thought the ZM 25 and 21 were very close in size.
Not quite - the Zeiss 4.5/21 is definitely smaller than the 2.8/25. Size, from the manufacturers' specs:
Zeiss 4.5/21: diameter 53mm, length 34mm
Zeiss 2.8/25: diameter 53mm, length 49mm
CV 4/21: diameter 49.6mm, length 24mm (28.5 w/hood)
Hope this helps, even if I haven't a pic side by side for both lenses. :D
Isn't it true that the measurement for the CV lenses doesn't include the flange, while that for the ZM lenses does? Once the 21/4.5 is mounted on a T, it protrudes about 27mm. Leaves just the right amount of room for my stubby fingers, yet is eminently pocketable.
You'll have to get it, Joe.
I already took off the flange :D still, is pocketable enough IMHO.
