kossi008
Photon Counter
I am considering buying an R4x to use with my 21 to 50 mm lenses, and I don't have a dealer close by. I do own the Bessa R, and am using it as a reference point.
(1.) The 21 mm frame:
According to my calculations, the 21 mm frame on the R4x should be about 25% bigger than the 35 mm frame on the Bessa R, unless the eye-point is radically different between the two cameras. Also, the 21 mm frame on the R4x should be roughly the same size as the 40 mm frame on the R3x. And since a lot of glasses-wearers report problems with the latter, I am wondering...
(2.) The 50 mm frame:
According to the same calculations the 50 mm frame on the R4x would be 10% bigger than the 75 mm frame on my Bessa R, so no problem for me. Yet a lot of people complain that it's tiny.
(3.) Focusing the 50/2:
Erwin Puts tells me (in his article on RF accuracy) that it should be no problem focusing a 50/2 on an effective RF basis of 19.2 mm. It might be less fun, but not impossible, right? Any experience is appreciated here...
(4.) The shutter noise:
My Bessa R is definitely noticable, maybe not on rush-hour sidewalks, but usually on a quiet street and certainly indoors. How does the R4x compare here (or any of the newer R's, for I guess they have the same shutters). Any differences between M and A versions?
(5.) No AE vs. manual discussion please. That's about the only thing I can figure out for myself.
I know the decision is up to me, but I feel I'm lacking critical info here, and the reading on RFF so far has left me confused ... 😕
