oftheherd
Recently I decided to check the accuracy of my turret finder on my Kiev 4am. I used some badly out of date Ritz 200 ISO film, not being worried about the quality of the film, but the accuracy of the viewfinder. I was surprised at how accurate it was. I also found I need to be sure it is not loose or wiggling so it is looking forward the same way the camera is. Otherwise, it will show the right angles, but not be centered.
Anyone figured out the best way to do that?
However, I noticed a very unusual thing when I got the film back. Two frames have a strange artifact. They are attached. In one case there is a blank spot at the edge of the frame. On the other, there is an area that seems to match, but it is just sort of blurred.
It doesn't appear to be a framing issue as I counted sprocet holes and the are the correct eight leading into and out of the suspect frames. The area isn't so well defined you might suspect something fell in there. It isn't development. The areas on the edge of the film have proper development as do the other areas of the film.
It isn't a shutter problem the best I can determine, as the Kiev is a vertical traveling shutter, not horizontal.
Anybody have any ideas.
