gmail.com
minoruta
When set to 800 asa at 2.8 is the meter cell at the top of the lens completely uncovered or hidden a little bit by the aperture hole ring?
I am asking this question as I repaired one and got a problem placing the aperture ring (with the various sized holes) back in place as it has two holes (hence two position options) and only one guiding pin to go on.
Thank You in advance for your help.
btgc
Hmm....don't have a MG-1 but Konica Auto S2 has similar construction of ISO-o-matic ring making wider or narrower gap to let light onto CdS eye. So basically I want to say that on KAS2 it's all made up such way that there's only one proper way to put together - sure Yashica engineers weren't less smart.
Just look at it after short break and idea will pop out; at least this happens to me.
gmail.com
minoruta
Thanks, I got an answer.
PS. It is not obvious because there are two holes that are close to each other and both of them fit.
mrwestphal
Hey gmail, just for info purposes, what did you find out on this so if I ever take mine apart I don't mess up.
gmail.com
minoruta
When you reassemble the aperture ring with the various sized holes for the meter, there are two holes but one guiding pin. The lower hole is the right one.
Guiding picture:
http://farm4.static.flickr.com/3148/2745248612_ef0845c434.jpg?v=0
Guiding picture:
