Using a 35mm lens on a CV Bessa R3M/A
kshapero
South Florida Man
9:14 AM
Anyone using this getup? I have persuaded a friend to try enjoying and owning a RF. I have an extra 35mm lens. He is dead set on an R3M. He is attracted to the 1:1 VF, so an R2M is out. I am thinking it would be no big deal to mate the 35mm lens with the R3M. Anyone?
I really like 40mm on the R3A. I know you can use the limits of the VF to guestimate 35mm but I think 40mm is the limit of comfort - I say this as a non-glasses wearer - though YMMV.
Having said that I get good mileage with my 28mm on the R3A too…with the accessory finder for framing of course.
I have an R3M, great camera, I think a 40mm lens and a 35mm are similar enough to use the 40mm lines with a 35mm lens. Should be fine I think.
I agree with thegman: more than using the whole frame, it's more comfortable framing with the lines for 40mm, just knowing the lens will see a little bit more...
Visually it's not easy composing with the whole window...
As stillshunter said, those lines for 40mm are the limit of comfort, and I don't wear glasses either... They're the limit even when you are very very close to the eyepiece.
Anyway, the 1:1 finder is so nice I prefer using it for a 35 instead of other cameras...
Juan
Hmm, guess I never really expect a rangefinder's framelines to be that accurate. The 40mm lines for the 35mm Color Skopar seems a great fit for my R3M. I use an external finder on my M3 but that is a little different beast.
35mm is basically impossible for glasses wearers (like me), but may be possible if you are familiar enough with the focal length and can at least see the window edges.
