Spider67
When I focus on infinity the lenses scale is on 25 meters. It's correct if used with a Zorki C.
So what can I do to correct that? I saw that the J9 in ltm can be taken down ito two components rather easily. I fould an aluminium ring that is probably a shim.
I tried to focus without the shim but the result was still the same.
What can you recommend?
The way I see it now the RF wrongly meters a the correct distance at 25 m so additional shimming should solve the problem.
Anyome with more experience in that matter?
best regards from Vienna
Dess
Dess
