using a translucent cap for incident metering/expodisk
ibcrewin
Ah looky looky
8:23 AM
I found that a translucent vitamin water bottle cap fits perfectly over the 35mm skopar lens. I know you can use frosted pringles cap for WB on digital from searching a few forums, but I also hear there is a way to use it as an incident meter.
How's that work? Meter off the cap and open 1 stop? 1/2 stop? Also, poland spring bottles (1 gallon) make great expodisks.
Right!.. Meter through..
I tried it with the Rebel XT and it worked good enough. I have a roll in the bessa r right now I am trying it with. (exp tmx 400) I'll probably soup that later this week with my expired HC-110. :wink:
Under consistent lighting take a meter reading off a grey card using the camera’s ttl meter then put the your vitamin cap on the lens and turn the camera through 180° and take a second reading, how much the two differ would give you some idea.
Sparrow has been thinking. Excellent, Sparrow. Here is a page from 'Existing-Light Photography' The Kodak Workshop Series, it should help, too. If this violates the copyright laws, just delete:
edit, it is difficult to read, but if you 'save as' to your desktop, you can print or read with an editing program.
I grabbed a cap like this from an old Sony FD-91 I sold a few months ago. It reminded me of a cap I was on a Leica CL years back. Some photographer had put a light meter dome (like from a Norwood Director) into the center of his cap to get incident readings. Because it was a spot meter he said it worked well.
B2 (;->
charjohncarter said:
You better calibrate it. I think you mean 'meter though' not 'meter off.' Maybe you don't?
Disputable. The old name for incident light metering was the 'artificial highlight method', after all. You're metering off a transilluminated highlight...
Pure pedantry, but worth a few moments' idle thought.
Roger
Funny.......
Funny.......
Sparrow said:
And then of course there is the K-factor to consider
Funny, I thought Quarks would come into the equation some where. Perhaps I should have some more Lepton Tea......
B2 (;->
