Using old TMAX developer
siracusa
9:10 AM
Dear all,
I've a half full bottle of TMAX developer that was opened around early 2011 (somehow I ended up using other developers and never got round to using up the TMAX). The liquid in the bottle has yellowed somewhat, and I was wondering whether it should be okay to use.
Any thoughts would be greatly appreciated!
David
Any yellowing normally means that the developer has lost some potency through oxidation which will result in under developed negatives. You could try processing a snippet of exposed film in it to see if you can get a decent black but my advice is not to use it.
Throw it away. Developer is cheap; ruined photos aren't.
Tmax Developer has a long shelf life, many years, but ONLY if it is in a full bottle AND stored in the dark. Kodak used to sell it in gray bottles; it lasted a lot longer than it does in the clear bottles they use now. This is because the developer is degraded by exposure to light.
It will be fine.
Like every developer after 30 rolls, etc.
It's still working, different than fresh, but still fine.
DDX: 2 months old, open bottle, 28 rolls made before this one:
It will be fine.
No, it will NOT be fine. The OP has developer that is EIGHT YEARS OLD. I've been using Tmax Developer for 25 years now, and I know what I'm talking about.
I stand by my previous advice: Throw that sh-t away and buy a new bottle. Your photos are worth more than the $20 or whatever a bottle of fresh developer costs. It amazes me the people on here who own thousands of dollars worth of cameras, drive $70,000 cars, and wear $8000 watches but insist on using old chemicals, outdated film, etc. to save money.
It is bad idea to throw unused chemicals. And not really necessary.
I discovered old TMAX, half used bottle in my previous office.
It was in use years before. Worked fine.
It's fine. And it's my opinion/ knowledge.
I am 33 years old, and less than 6 months in photography. (My zodiac sign: Pisces)
But do you ever used old one?
Or non because "no"?😉
I stand by my advice: use this "sh-t "🙂)
Ps. Why are you talking about saving money?
Henri Cartier Bresson said:
"Do not believe in anything simply because you have heard it. Do not believe in anything simply because it is spoken and rumored by many. Do not believe in anything simply because it is found written in your religious books. Do not believe in anything merely on the authority of your teachers and elders. Do not believe in traditions because they have been handed down for many generations. But after observation and analysis, when you find that anything agrees with reason and is conducive to the good and benefit of one and all, then accept it and live up to it.”
Also check this parade:
Dear all,
David
Depends somewhat on how good you are with Photoshop.
LOL. Thanks for posting the photos! Personally, it looks like I would prefer to avoid the old used-up DDX. Not sure what your results with old DDX has to do with T-Max developer, as well.
I have an old gallon jug of T-Max dev I was given years ago, and it does work just fine despite being over 10 years old. But, I tested it first, and would absolutely agree that if you have important negatives, it's always better to use fresh developer if you want to be safe. I only use T-Max dev for a couple of films I don't use often.
So, let me get this straight: Some beginner with 6 months of experience is going to tell a professional with 25 years of experience how things work?
It amazes me the ill-conceived, scientifically false advice that people with ZERO knowledge will give, and then defend to the death.
To the OP: You came here asking for advice because you want your photos to come out right. Right? If you didn't care about the quality of outcome, you'd have just used the ancient developer. The loudmouth that I responded to above has zero knowledge. Full stop. He admits to having a mere six months of experience. Your developer is EIGHT YEARS OLD. I have TWENTY FIVE years experience developing film using the very same developer you are using.
Tmax Developer will not last eight years in a half-full bottle. You may get images on your film, but they'll have little shadow detail, they'll be grainy, and the contrast will be low. Why bother?
The loudmouth above can give you the advice he did because IT ISN'T HIS FILM, so he doesn't have to care if you ruin it and lose your photos. I care because I'm a teacher who still believes in the quaint idea that I have an ethical obligation to be honest. I know that in the postmodern, post-truth era, that is an outdated philosophy, but I am sticking with it.
Dear all,
David
It will be okey to use it.
Greetings!
best way is to take a test roll and soup that. wouldn't hurt to d a second test but that should you give some indication of developer activity.
And you don't need 25 years of experience to do this!
It's not a rocket science. It's chemistry. Level... Beginner 🙂
Greetings!
What in your six months of experience has told you that eight year old developer in a half-empty bottle will be good?
People like you damage the community we have built here. A community based on knowledge, honesty, trust, and a desire to help others. Go troll somewhere else.
I think we should all show respect for experience and knowledge from our photo-elders and come-befores.
The desired outcome will change from generation to generation as it did for the elders and their predecessors.
If I have learned anything here on RFF it is: Try it yourself and if you like it then it is good and you are done. Otherwise, seek advise.
Sent from my iPhone using Tapatalk
Sorry Chris i don't have time to deal with your ego (ego, not community), but of course it's funny to read your reaction😉 "25 years of experience" is my favorite case😉
my six months of experience, told me that you can use old developer. Even if it's tmax in a half-full😉 bottle.
Tips and tricks: test roll
You're right. Everyone should question and confirm things themselves. Common "wisdom" is sometimes not relevant or even wrong.
However, this includes questioning the source and their experience. Luckily for the OP, you've posted some photos that help illustrate your point. Rather anemic contrast and overly grainy images may not be his cup of tea, and if so he would do well to ignore your suggestions.
One should always test on their own, and verify. It's also good to note common indicators, like yellowing of the developer as mentioned above. For some reason, my T-Max developer hasn't yellowed in years, so maybe I'm just lucky. If I poured some out and it was yellow, I would throw it away. I got burned by XTOL before and if I had known back then that yellowing indicated dead developer, I would've been better off.
Your experience is using a different developer that is only two months old. Completely irrelevant to the OPs situation.
Experience matters. I have used the OPs developer and it will not work. Don't like my 'ego'? Then LEAVE.
100% Agree.
Take care!
