nickthetasmaniac
Hi all, I've recently tried scanning my first batch since upgrading my MacBook Air to OSX El Capitan 10.11.3, and I'm having some issues.
I'm using an Epson V550 with Epson Scan 3.9.4 OEN, and I've installed the recommended update for use with El Cap.
I prepare everything exactly the same way as always (with up to 12 negs), but when it starts scanning it will only move from one scan to the next if I...
- move the cursor over the progress box (if the Epson Scan app is at the front);
- bring the Epson Scan app to the front (if it isn't)...
Ie. if I press 'scan', if won't run through the whole 12 by itself. BUT, I don't actually have to press anything to make it do the 12, just run the cursor over the box...
I'm not sure if I've explained this well, but it seems to bizarre I'm not sure how to explain it logically... I'm going through about 15 rolls so obviously it's a significant hassle if I have to prompt it to scan each frame.
Cheers, Nick
Cheers, Nick
gnome chompski
http://www.rangefinderforum.com/forums/showthread.php?t=153936
you are most likely missing the patch.
nickthetasmaniac
Perfect thanks (apologies for missing the other post, I wasn't even sure what to search for...)
