vc nocton 50mm f1.5 vs leica dr summicron, (old) 50mm f2
As far as sharpness is concerned, a new Nocton is better than an old Summicron even in good shape but the difference is character. The Nocton is a modern lens with plenty of contrast. The Summicron as perhaps less contrast but a particular 3D bokey that helps to separate things in the composition and - according to me - this compense this difference in contrast.
In both cases, these lenses need a lens hood if you want contrast.
I've used both.if you don't need 1.5 the DR is the way to go. It's tiny, takes 39mm filters, whereas the big Nokton takes 52 mm filters.
i appreciate the responses.
the bokea of the summicron is possibly more important than sharpness to me.
