Aurelius
Do you know of any lenses that are "verboten" to use on the ZI (that will not work)?
sebastel
coarse art umbrascriptor
verboten?
as far as i know, there are none.
but if you refer to lenses that may be incompatible for some reason, there may be some. i suppose, especially collapsible lenses should be used with care, as well as some wide angle lenses that use deeply recessed rear elements.
but there is no penalty on using them, except the possible damage you cause to lens and/or shutter.
Aurelius
sebastel said:verboten?
Yes, this is what i had in mind.
Can the J-12 and older Leica wides cause this kind of damage?
