Vertcal streaks
X360
2:09 PM
Hello. My last batch of photos has a white vertical band from top to bottom and It also shows on the negative. In sunlight it shows up as a discoloration and in low light shots I can see a white band clearly.
The girl developing said that It looks like I opened the film compartment.
Anyone else experience this on their Yashica? Any ideas what might be causing this?
Sure sounds like a light leak, at the hinge end probably. Is the mark slightly right of the center of the frame?
Have you replaced the light seals, or are they original?
Russ :D
on this last batch I noticed it on the left right and center. Sometimes its red and sometimes it's white.
I'm going to shoot another roll to see if I can characterize it a little better.
I am having the same problem, mine happens on the left side. I think it is the light seals because the longer I waited to take the next shot the more I could see it. It didn't happen on every frame because I shot a few right after another leaving no time to get light inside and expose the film.
