Vignetting workflow w 15mm Heliar/R-D1s
victoriapio
9:45 AM
RFFers,
I am trying to lick this vignetting problem with the 15mm f4.5 Heliar and am not having a whole lot of luck without introducing noise (sometime substantial) in the corners.
What workflow are you using to overcome this falloff? I use CS2 and would like to keep it as my only "processor" for both my DSLR and the R-D1s. But I am open to any successful strategies with any of the RAW converters.
Any help is appreciated, thanks in advance,
O.C. Garza
You can get rid of this vinetting using EPSON photoraw program.
It works fine even though it will left digital noise a bit.
I use the Epson PhotoRAW software.
I tend NOT to use the 15mm setting but the settings for 2-3-4 focal lengths longer, sometimes settling for the settings for 50mm. This reduces a certain amount of vignetting but more importantly prevents corners that seem too bleached out and noisy.
Then again, I often just let the vignetting be. It can really add something to a shot.
Truth be told, I don't use the 15/4.5 very often. While I very much enjoy the 25mm on my Bessa L or R, I can't get used to the 15mm on the R-D1.
Agree with RML, I find the 15mm vignet setting of PhotoRaw too strict. If other adjustments are included (curves, color filter in B&W, EV correction) the noise gets sometimes too strong, then I export it unedited in 16 bit to CS and do everything there.
But a certain amount of vignetting is Ok - it belongs to wide angle shots. Here one of my PAWS - the dark border at the top does not disturb me at all.
Didier
Best limit the correction for vignetting in CS2 to less than 40%. I think PhotoRAW does a better job (less noise) but agree with the other comments here – it's annoying for certain critical shots, but you really have to live with a little vignetting…
Didier
Nice shot and I agree any vignetting in it looks quite normal.
Thank you
O.C.
Vignetting w 15mm Heliar
victoriapio said:
RFFers,
O.C. Garza
Thanks for all the comments and suggestions RFFers. While I admit some vignetting certainly looks normal and can at times enhance a photo, in other photographs it really is a hinderence.
I have been having some success with the dodging tool on CS (see attached photo) but the vignetting tool in CS seems a bit crude. I will experiment with the settings based on your suggestions.
O.C.
I went to take the 15mm off the R-D1s body and found out the lens had loosened from the adapter a bit. That didn't help the vignetting at all ;>) Things looks "back to normal" now...
O.C.
