Vinetting on a GW 690
Gravatar
2:39 PM
Hello all. I am having a bit of vinnetting on the corners my GW 690. This doesn't seem to happen in all of my shots and I was wondering is you could make some suggestions to minimze this. Firstly, I keep a UV filter on the camera to protect the lens. Could it be catching the edges of this at the lower f-stops or is the lens coverage just a hair too small? Also, is there some vinette repair software you all might recomend. Feathered select brightening coupled with dodge and burn is more than a little tedious. Thanks for the suggestions.
Grav
