VM Ultron 35mm 2.0 asph. version II –– Anyone?
Aristo
10:40 AM
There are remarkably few images to be found on the internet of this lens mounted to Leica M bodies.
The best ones are on the bartenders Cameraquest-website but they are nearly the only ones and they are a little bit low-key. Would like to see some more normal examples...
Does nobody own this lens?
Aristo
Gotcha. Are you trying to get an idea of it's aesthetics, size, or something else?
Yes exactly, I'm tso trying to get an idea of the aesthetics and of the size of the version II on a (idealy black) Leica-M body.
Thank you very much nickthetasmaniac. greatly appreciated!
The version II Ultron 35/2.0 has the same optical formula as version I, right? I may be mistaken, but I think the only difference between version I and version II is in the focusing tab. I have version I (w/ the focusing stick) and have used it extensively over the last couple of years. It is an incredible lens. If you want to see pics, go check out the thread on version I…
Yes, optically the two versions are identical. The whole barrel design is different though, not just the focussing tab.
I have several great 35mm lenses in LTM or M mount, so I focused on CV lenses that I had no other lenses like them.
the CV 50/2 APO and the CV 50/1 were my last two buys:
