splaaash
I bought a 21mm f4 Vogtlander last year,when it arrived it was a Nikon-s with Leica M adapter
Is there a leica screw adapter for this lense?
Phil_F_NM
Camera hacker
The rear collar that holds in the rear element on that lens interferes with the focusing cam follower in the Leica M body which is what causes the focus error. Using this lens, there is no way around it to get accurate focus coupling. You could get the wide angle offset Amedeo adapter but it does not offer focus coupling with Leica bodies.
Phil Forrest
Dez
Bodger Extraordinaire
Then again, who really needs a rangefinder with such a wide angle lens?
Dez
Dez
splaaash
I use it from time to time on my NEX 5,Im fear it just going to sit somewhere Its the only vogtlander lens i dislike
The aperture ring is very loose as is the focus.not an easy lens to use.i thought it needed greace to damp it
It needs somthing,guess i was ripped off,same German retailer that asks 499€ for the 15mm without the finder---secondhand
