Voigtländer Vito BL: lazy shutter blade
pinkarmy
7:54 AM
i am in my "crazy for Voigtländer" period ever since i got my well-used Vito III, Vitessa A3 and Vitomatic IIIb, both have rangefinder and the wonderful Ultron f2 lens.
They are both GREAT! (except the vertical alignment is a bit off on the VITO III)
tempted by fellow RFF member farlymac's posts on the Vito B/BL,
i got myself a Vito BL, a Vitomatic 1 and a Vitomatic IIa (it is still in the air somewhere between Europe and Asia:(), all equipped with Color-skopar 2.8 lens.
i found the first rolls from the Vito BL and Vitomatic 1 more than satisfied.
the two cameras are basically the same thing with slightly different exposure meter designs, and i am more fond of the Bewi Automat meter on the Vito BL, which you need to press a tiny button for a second to take the reading.
the guess-focus (which is my weakness) is surprisingly easier on these cameras then my other scale/guess-focus camera...wonder why.
the slow speeds on Vito BL are sticky so i dry-fired it for a whole week
it seems to improve a bit
however after i laid the camera down for a day, the shutter is lazy again.
i believe i can apply a drop of Ronsonal to the blade, can't i?
That might help in the short term, Pink. But in reality, if it is starting to stick, it really needs to be taken down a bit and thoroughly cleaned. If not, it will just continue to stick again after a period of non-use.
PF
