Voigtlander 15mm f/4.5 + B+W nano?
shinleung
8:01 AM
Hi everyone, I am new here.
I just want to ask if anyone have got the voigtlander 15mm f/4.5 and is B+W xs-pro nano going to fit on it?
I am asking because I am aware the nano filter have a slightly bigger diameter than normal filters and the space around the hood seems to be tight enough with normal filters.
Also, is it recommend to put filter on this lens?
Thanks a lot
What camera?
If you are shooting an APS-C camera a filter extender will be very helpful:
http://www.fotobrenner.de/default.a...Anf=1&Ende=10&SON=5&UE=11,52,371&MENPRO=2&ES=
Its not a step-up or a step-down, its only 52mm to 52mm. Everyone who is using a not full frame camera should use these extender. With it you can put very easy your filters up and away from the camera. No more finger fiddling with the built in lens hood of the Heliar 15.
