Voigtlander 28mm F2 Aspheric $899
CameraQuest
Head Bartender
Staff member
1:42 AM
Voigtlander 28mm F2 Ultron Aspherical M
SHIPPING JUNE 10TH $899
Voigtlander's redesigned 28mm Ultron is sharper, smaller, lighter, and available in your choice of three classic lens styles
It features improved optical performance
with 10 lens elements in 7 groups
using two Aspheric Surfaces and two Abnormal Partial Dispersion Elements
This new 28mm Ultron II offers the same popular lens
barrel choices as the Voigtlander 35mm F2 Ultron II
Main Features
■ Type II Classic 1970’s rangefinder styling with quick handling classic focusing tab for fast easy focusing
■ Type II Black Paint with Brass Lens Barrel
■ Beautiful Bokeh with 10 aperture blades
■ Small Compact Lens Size using small 39mm filters
■ Manual Focus with all metal lens barrel
■ Aperture range F2 to F22
■ Filter Size 39mm
■ Close Focus .5m mirrorless or .7m rangefinder coupled
■ Weight 8.1 ounces Type II
■ Focusing Scale in both feet and meters
■ Diameter 52mm Type II, Length from camera mount 51.4mm
■ front and rear lens caps included
■ Optional LH-4N or LH-12 Lens hoods​
Fantastic! They finally did it! I was just playing with my Elmarit 28 and thinking I wouldn't mind another stop of brightness.
I wonder when it will land in the UK. How will it compare to the slew of RF mount 28mm F2 lenses out there.;)
I haven't bought any photo gear since mid-2018 but I'll go for the silver version of this lens whenever it is available in Vietnam. Cheers, OtL
The new smaller Voigtlander 28mm F2 Ultron II Type 2 is on the left,
the previous non aspheric 28mm F2 Ultron on the right
Obviously huge step above from old 35/2. Into the right direction :) .
Just bit too long for my taste. One cm longer than Cron. But 39mm filters size sounds promising not to ruin 28 framelines.
Wonder how it is M's VF.
Lens looks cute enough to have as the only 28mm lens. It is Cron 28 killer lens. Just like 35/2 rendered 35 Cron to just a status lens.
I would like to see a photo of the new lens against the Leica f2.8 which is a smalp lens. It would not be much bigger.
