Yokosuka Mike
Abstract Clarity
Voigtlander 50mm f1.2 Nokton VM lens, Sony A7II camera
Yokohama, Japan - September 18th, 2018
So, I took the new lens out today for a test drive. I thought people here might be interested; maybe you are, maybe you are not.
If you are, please enjoy, if not, oh well. By-the-way, it's a manual focus lens so not every shot is perfect.
Mike
Mike
Erik van Straten
Mike, very nice results! Thank you for sharing.
Can you make some shots with this lens with straight lines alongside the borders of the frame? Uncorrected? I would like to see if there is any linear distortion. That is very important for me as analoge photographer. Thanks!
Mike, I am sorry, I didn't want to ruin your beautiful portrait, I only wanted to show how well distortion in your lens is corrected.
Erik.
Erik.
Michalm
Looks like nice lens , I wonder how well would it work for landscape photography on A7 cameras.
Yokosuka Mike
Abstract Clarity
Erik.
Hello Erik,
Next time I go out I'll see what I can do and post it up for you.
Mike
Yokosuka Mike
Abstract Clarity
More from the first outting.
Mike
Mike
Yokosuka Mike
Abstract Clarity
Yokohama, Japan - September 19th, 2018
Erik, here are some straight lines from today for you. I hope this is what you had in mind.
These are just fun stuff from today.
Mike
Mike
Yokosuka Mike
Abstract Clarity
Yokohama, Japan - September 2018
Mike
Mike
Mike, a suggestion! It's great that you post a ton of photos in a range of threads, but everyone with limited bandwidth will appreciate them even more if you limit the long side of your posted images to 1024 pixels, and instead embed links to the 1600 x 1067 pixel images.
Erik van Straten
Mike, thank you for the straight line pictures! There is no distortion.
Erik.
Erik.
Yokosuka Mike
Abstract Clarity
Jon, thank you for the suggestion. I'm a bit challenged when it comes to pixel stuff. I'll see what I can do.
This is a test:
This is another test:
Mike
Contarama
Fantastic! Thanks for sharing
Yokosuka Mike
Abstract Clarity
Thank you, Contarama, I appreciate your kind comment.
All the best,
Mike
Yokosuka Mike
Abstract Clarity
Woman on the street
Mike
Woman on the street
Mike
Yokosuka Mike
Abstract Clarity
Gone Fishin'
Second Honeymoon
Mike
Gone Fishin'
Second Honeymoon
Mike
alexandru_voicu
Nokton 50/1.2 wide open on Leica M6.
Fomapan 200 @ EI 100, XTOL 1+3 for 10 minutes at 20C
focus030 by gordon_comstock, on Flickr
focus034 by gordon_comstock, on Flickr
Carey M
A grab shot, wide open, taken with a Leica M3 at Photokina 2018 Messe.
Voigtländer 50mm f/1.2 Nokton VM @ Photokina 2018 by Carey_M, on Flickr
rcubed
Canadian
Any focus shift on this lens? I got rid of the f1.1 because the focus shift was unmanageable for me.
alexandru_voicu
There is some focus shift, but that is to be expected from such a fast lens. It's bearable, though. When I got mine, I put in on a tripod to check it. At F1.2 and F1.4, I have some slight front focus, but things are not that obvious when shooting in real world. At F2.0, focus is spot on. From F4.0, it goes slightly backwards. But, again, these are my results at minimum focus distance. I guess that focus shift will be even harder to notice at longer distances.
While I've never owned a CV 50/1.1, my guess is that 50/1.2 has a much more manageable focus shift.
Erik van Straten
I've never seen any focus shift on my copy of the Nokton 50mm f/1.1, but that lens doesn't focus closer than 1m and I've never used it on a digital camera.
Erik.
Erik.
alexandru_voicu
In my experience, most lenses exhibit some degree of focus shift. Even my Planar 50/2 suffers from it, although the shift can be measured in millimeters at minimum focus distance. But this can only be measured in a controlled environment (good eyesight, good lighting, tripod and test charts). In real world, it's close to impossible to spot. The only lens I have without focus shift is the Zeiss Distagon 35/1.4, but this one has a floating element.
As for the Nokton 50/1.1, being such a conventional design (no floating elements, no aspherical elements), I am convinced it must show some degree of focus shift. It would be miraculous not to.
Alex
