Waterproof bag for 2 Leica M's
ekbladfred@gmail.com
Fred Ekblad
11:11 PM
Hi!
I'm trying to find a bag that is waterproof and can hold two Leica M6 cameras with a Summilux 35 ASPH FLE and a 50 Summicron mounted.
I also want it to be able to couple with a chest holster like this: Link
The holster I can actually build myself if for some reason the Digital Holster Harness would not fit.
Something like this but meet up to my specs would be great: Click here
But it could also be a bag that comes with some sort of water protection cover.
Any ideas?
Hi!
I'm confused what you're looking for... based on your requirements why not use the ThinkTank Digital Holster you linked? Is it the wrong size or something? The ThinkTank Digital Holster bags include a rain cover in an outside pocket that you can use to cover the holster, and the material is water-resistant coated nylon as well.
Ortlieb Aqua Cam - can hold two M's in padded insert.
http://www.ortliebusa.com/prodInfo.asp?pid=41&cid=2
Also at B&H just below the zoom bag you showed '
http://www.bhphotovideo.com/c/search?atclk=Brand_Ortlieb&ci=9437&N=3828168041+3940189318
Thank you for your replies!
Well I want it to be waterproof and not just water resistant. I'm spending a month walking in the amazon so when crossing rivers it would be nice to have something waterproof.
The Digital Holster 2.0 series looks like they are shaped for DSLR cameras even though two rangefinders would fit inside.
That Aqua-cam bag looks good! In the description it says "against dust and spraywater" but in the manual HERE it says waterproof so I guess it is the same as Aqua-Zoom. The weight is good as well.
If its possible to put a separator between the cameras that is great.
Ortlieb sells THIS harness as well that looks nice so Ortlieb definitely looks lika a good option
Remember,
waterproof bags will keep moisture inside to, so in very humid conditions keep heaps of desiccant/silicagell in the bag to avoid mildew.
Remember,
Thanks for the reminder! Yeah desiccant is a must in the rain forest. It's easy to make it yourself so I usually do that to fit the bag or whatever in a nice way.
This bag: LINK
Is the closet to meet my specifications that I have found.
Well, Ortlieb has a longstanding good reputation for the durability of their bags. I think they made their name with durable, waterproof trekkingbags for bicycles.
Lycka till med jakten efter den perfekta väskan, mr Ekblad :)
Thanks for all your suggestions! Your help is greatly appreciated and needed. Thanks :)
Wow this utility bags from Watershed looks great!!
Ok it seems like there is a few choices out there. Thanks a lot everyone. I will update on what I got and how I find out after using it.
Wow, Watershed bags seem to be the bees knees.
I am starting to save for one of those tapered flotation bags and one of the smaller bags.
I just finished the Bass Strait crossing and roll top Bags aren't safe enough for critical gear (in my case things like a down sleeping bag)
