Matthew Runkel
Since a standard Bayer filter has rows of red and green filters alternating with rows of blue and green filters, more photosites on a sensor are capturing green spectrum than seems strictly necessary (although I gather there are sound reasons for doubling up on green).
If half of the green filters were replaced with filters blocking all visible light and UV the sensor would provide a channel of IR-only data. Infrared would then be a known quantity, and firmware could then subtract out the influence of infrared on the RGB photosites. Perhaps this scheme would even allow Leica to omit the technically vexing IR filter. (This assumes that the filter for non-IR spectrum could be produced with a normal dyeing process and would not be susceptible to the same angle-of-incidence problems associated with dichroic filters.)
Might this have been a workable approach? I would assume this is something that Leica and Kodak would have considered but rejected for sound technical reasons. Perhaps without the "extra" green photosites it would not be possible to get a quality 10MP image from the sensor. However, if the M8 design process heavily favored off-the-shelf components, an approach requiring a new Bayer filter might not have been explored. If the approach would work in theory, could the M8's existing sensor be retrofitted with a modified Bayer filter?
