What battery Minolta?
oftheherd
11:37 PM
I recently acquired a Minolta SRT 101 in excellent shape. It does need a battery for the light meter. It had a PX 13. I don't even know what that is. Is that one of the old mercury batteries? Is that a modern battery and one that will allow the meter to function correctly?
At any rate, what battery should I be using? A PX 13, some flavor of wein? What say those of you who are currently using those fine old cameras?
Yes, the SRT-101 took a mercury battery. i have one of these cameras and the choices are the Wein Cell or the CRIS adpater that lets you use a modern silver-oxide battery. I put a Wein in mine to test it when i first got it and when it died i never bought another since I usually use a handheld meter with old cameras like that. But the Wein worked well
I guess it is an easy adjustment to modify the meter to work properly with a modern battery. If you send it in for a CLA ask that this be done. There are also instruction somewhere on line on how to do this yourself. I don't remember where, never bookedmarked it, too many thumbs.
The original battery was a 1.35 volt mercury one. You can modify the metering circuit (easier than it sounds) with a Schottky diode to have it accept modern 1.5 volt batteries.
Wein cell. Works in my QL17, EF, M5 (two) and Gossen Luna-Pro. All of these originally used 1.35 mercury batteries. Just remember to switch the meter off when not in use.
I soldered a schotkky diode inline to reduce battery voltage and use a 357 silver oxide battery with rubber "O" ring as a spacer.
The diode method has been mentioned and quoted over and again on various websites; I gave it a try and found the response to be non-linear. I shall send the recalibration method files to my camera technician and see if it is a more viable method.
Some years ago at Darkroom & Creative Camera Techniques (now Photo Techniques) a plan for building an active voltage stabilizer circuit was described which gives even greater stability than relying on the output voltage of the mercury battery. I will take another look at it and see if it can be used somehow.
