What camera for these lenses?
Derek_Teixeira
5:51 PM
If these are indeed T2 lenses, then these would only work as preset lenses (i.e., no auto-diaphragm). You would open the aperture wide to focus, then turn the preset ring---it will stop at the aperture that you had already set at, then shoot. It is not much slower than an auto lens, but you just need to get used to the routine with a little bit of practice. If you forget about turning the preset ring, you'll over-expose with the lens wide open.
I still have a few preset lenses from the 1960s/1970s. These were cheaper than the auto versions, if at all available.
