Frankie
Speaking Frankly
The ZM only provides 28/35/50/85mm frame-lines.
I know for a fact that the M-mounted CV 40mm/1.4 will bring up the 50mm frame line unless one of the mount claws is modified...which I have done under the kind advisement of TomA.
[I have predicted and later verified that the FOV of the 35mm frame-line (~85%) is closer to 40mm —35 mm x 1.15 (100+15%) = 40.25mm— by placing a Nikon F/F2 ground glass (matte film also works) at film plane with shutter set at B, camera tripod mounted, and checking FOV at infinity and close, through large to small apertures…]
What else do we know?
I have set up a blank table below hoping RFF members with actual experience may contribute. Perhaps the Moderators could set this thread up as a Sticky…
Lenses /Frame-line /If modifiable
21mm /50mm /?
25mm /35mm /?
28mm /28mm /NA
35mm /35mm /NA
40mm /50mm /35mm
50mm /50mm /NA
75mm /35mm /?
85mm /85mm /NA
90mm /85mm /?
135mm /? /?
New data from yzblog for 21mm
New data from Cameraquest for CV 25mm/4P
New data from watchyourbackground for CV 75mm/2.5
New data from jdvf for 90mm M-Hexanon
21mm /50mm /?
25mm /35mm /?
28mm /28mm /NA
35mm /35mm /NA
40mm /50mm /35mm
50mm /50mm /NA
75mm /35mm /?
85mm /85mm /NA
90mm /85mm /?
135mm /? /?
