What framelines do you use?
lancey
7:05 AM
I have been using the 28mm frameline for my 35mm lens on the rd1s. It seems to fit nicely. is this normal? I thought I should be using the 35mm frameline but that is too tight IMO.
How about you?
In general, I use 35mm frameline for 40.
For all the 3 framelines, I'll say they are accurate at around 1m~2m.
When I'm at 3m or further away, I need to set the "wider one", or just guess.
BTW, the life-size viewfinder helps a lot when using 28mm.
(Some of us can use the "whole" viewfinder for 28mm, but I wear glasses.)
