The curve has a very short toe, and is upswept in the lower tones but straighter in the higher tones.
Marty
From my own experiences and different tests with Acros in a lot of different developers I have to disagree.
I have to disagree in the following way:
The phenomenon you have discribed can be there: But only with certain developers or certain dilutions.
But it is
not a general characteristic of Acros.
As with every film the results is very dependant on exposure, type of developer, dilution of developer, agitation rhythm.
The above described phenomenon is also there with Tri-X or FP4 + if you choose the"wrong" developer or dilution.
Example:
With Adox Rodinal alone I can get 4 (!!) completely different results / characteristic curves with Acros!
ISO 100/21° and dilution 1+25: Short toe, upswept curve, blocked highlights.
ISO 80/20° and dilution 1+50: Longer toe, less upswept curve, brillant highlights with good separation.
ISO 50/18° and dilution 1+75: Very good shadow detail, almost perfect linear characteristic curve. Wonderful separation of tones and perfect tonality.
ISO 40/17° and 50/18° at dilution 1+100: Very similar to the results with 1+75, but with lower density in the highlights (compensating effect).
With Acros it is
exactly the same as with every other BW film:
Decisive is the right combination of film, exposure (use of real effective speed), developer, dilution, developing time an agitation rhythm.
To find these perfect film-developer combinations is essential for results in BW.
And by far the best solution to find these perfect combinations is using the perfect method BW experts are using for decades:
Use a densitometer and evaluate the characterictic curves of the film-developer combinations.
This method is
- by far the most precise
- it gives you all the information you need at once
- it is very easy
- it is very cheap.
Those who want the best BW results consistently should go this route. They will have much better results compared to their former ones, they will have much much less frustration, they will have much more fun shooting BW film.
Cheers, Jan
