What is the best way to use a 35mm with the SP?
rob.nyc1
11:22 AM
Hey guys,
How do you guys use your 35mm lens with the SP? Do you use the tiny built-in viewfinder, an external viewfinder, or do you just shoot through the main viewfinder and estimate?
Best,
Rob
The main life-size viewfinder on an SP isn’t wide enough to show a 35mm field of view, assuming the entire area of the viewfinder is used, including outside the 50mm frame. The 50mm frames are actually pretty close to the edge. Hence: I use the built-in 35mm vf.
An S3 on the other hand still has a life-size view but with full 35mm framelines as well as a little extra area outside the 35mm frame.
