What is this faint black shadow line on top of my photos/negatives?
bud.petal
5:56 AM
Hi all,
I have a problem with some of the photos from my Leitz Minolta CL (M-Rokkor-QF lens). About a third to half of the photos have this strange faint (and sometimes darker) black shadow. It's always in the same spot at the top of the photo and it also shows on the negatives/slides.
Does anyone have any idea what could be causing this?
Thanks,
Eran.
Did it used to be OK, and this is a new development?
It has been doing this since I bought the camera about 6 months ago. But since then I had the camera CLA'd and I shot a test roll (from which these 3 photos are taken) and it is still producing these lines. Could it be the lens maybe?
Looks to be a curtain problem. The flagpole is interesting, but it's a strong highlight. Assume it's overwhelmed the general reduction of exposure in the zone resulting from first curtain bouncing back in.
Can I suggest that all the affected images were made at higher speeds. Yes?
Because the effects of bounce usually last only a few milliseconds, when it occurs at slow to medium speeds the effect relative to the nominal exposure time is negligible. At, say, 1/1000 or to a lesser extent 1/500, as a percentage of the nominal exposure time the additional exposure (if the second curtain is bouncing) or reduction in exposure (if it's the first) become significant enough to matter.
In some scenes, Eg a variety of foliage, the bounce may be happening but the variation in tonalities may make it less obvious or even impossible to spot. On the other hand an evenly illuminated sky is going to betray exposure variations across the frame much more easily.
Hence, if you suspect bounce issues, a series of images of a scene of even tonality and consistent illumination, at shutter speeds from maximum down to 1/125 or so, will usually inform the diagnosis.
It's probably your camera's film gate blocking some of the light getting to your film. Take a look and see if the film is riding where it needs to be when you put another roll in the camera and advance it a little to get the film taught. Remember that your camera exposes the image on the film upside down and backwards from how you view it, so the problem w/ the film gate would be at the bottom not the top. Sometimes this happens when the film is not loaded exactly in the center of the take up spool, or it could be just a small misalignment in how the film canister rides in the camera. If you look carefully w/ the film in the camera (you will only lose a few frames on the front of the roll) you should be able to puzzle out what the problem is.
Since you're sending the film out to a lab, the problem could conceivably be on their developing end, so if you ck things out as I mentioned and all looks good, try another lab.
Maybe a dumb question, but are you sure the defect is in the negative? Or could it be in the scan or print process, not in the negative?
Steve that's always a possibility worth bearing in mind, however if this was the problem then one would expect it to be present in all of the frames on a roll, yes? Though depending on the obstruction, I could appreciate how portrait v landscape might give different results, if the obstruction has any flexibility and may move around.
We're still waiting for additional information from the thread starter, but the examples shown all look to be taken in plenty of light, suggesting higher speeds than lower. I'm sure it's caused by the first curtain bouncing. Whether the camera was recently serviced or not the shutter's not spot on. If the curtain spring tension is correct the brake needs attention, otherwise the tension might be too high. Either way it's not manifesting badly so ought to be able to be corrected.
Cheers
Brett
Thanks for that. Most of the photos I took on this roll were shot on 1/125 or slower, usually on f16. It's hard to tell by looking at all the photos on this roll whether the shutter speed had anything to do with it. I didn't shoot any photos on this roll with faster than 1/125 speed.
You can only notice the black shadow line on light backgrounds like a blue sky.
Thanks for that. That makes sense. I'll definitely check what you suggested!
