What next for my GSN
rayw
8:20 AM
I have ascertained that the pad is fine, I have sprayed the shutter slide contacts with switch cleaner to help with the over.under exposure lamps problem.
When I point at a bright light source, the meter appear to react to the aperture ring being turned.
Also the shutter is firing at different speeds.
The problem I have is that at F11/16 the shutter fires but stays open.
The only way to close it is to step down or turn the winder.
The other problem is that the camera seems unresponsive when not pointed at a direct light source.
Any suggestions?
Sounds as though you have a serious failure in the meter circuitry. Might be time to pick up another one...
Russ
