What the Heck Happened!?!?!? Help!
dazedgonebye
6:30 PM
I ran a quick 12 exposure roll through the new fed-2/jupiter9 combo and I'm not sure what happened.
The film advanced to frame 1 at least. There's a shot there that looks pretty good. Unfortunately, the rest of the roll is blank--with the exception of 4 small light leak looking streaks.
I'm imagining the possibilities:
1) I took one shot then put the cap on. No, I took the first few shots one after another, so if I have one, I should have several.
2) The film advanced to the first frame but slipped from there on out.
3) Some bizzare malfunction related to the shutter.
Any ideas?
The shutter delay arm isn't catching the second curtain if my experience with the Zorki 3M is anything to go by :( try winding on and firing the shutter with some tension still on the wind on knob whilst looking through the back of the camera , if that fixes it check for dirt and gunge ,old film chips etc catching in the gears of the rewind mechanism as thats what it was with my 3M which was not allowing a full wind on .
Paul
That looks right. I've been working it and it's now firing about 3 out of 4 times.
I guess I'll take a blower to it and see what that does. Am I going to have to start taking things apart here?
Oh just a thought , if you look at the bottom of the shutter cage theres a flat spring that holds the delay arm up until the shutter is released , You can see a small piece of rod protruding out of the bottom if you carefully lift the spring,This is the shutter pawl that delays the second curtain . If you cant see this rod or it doesn't appear to move as you lift the spring the shutter pawl rod could be sticking causing the second curtain to be released at the same time as the first .
Hopefully not , Try blowing it out and maybe apply a very small amount of lubricant , 3 in 1 oil thinned 50/50 with lighter fluid ,applied to the gear teeth with a cocktail stick does the trick .
Btw welcome to the wonderful world of FSU cameras ;)
Paul
It seems a bit more reliable after the blowing. I did notice that a with few shots at 1/60th, the first curtain stalled about halfway across before moving on.
I would just work it for awhile ,In most cases that will sort it , You could also try leaving it on a windowsill above a radiator , A nice gentle warming can get the yak spit flowing nicely and has given me a short time fix for a few sticky shutters :D
Paul
Thanks for all the advice Paul. I'll work it over tonight and see what comes of it.
Funny, the other Fed-2 fires like a charm but has an iffy rangefinder. This one has a questionable shutter with a great rangefinder. Both cameras are showing me great potential then disapointing me.
There are a number of relationship parallels here that I won't go in to.
Funny, the other Fed-2 fires like a charm but has an iffy rangefinder. This one has a questionable shutter with a great rangefinder. Both cameras are showing me great potential then disappointing me.
No problem Steve , glad to help .
The great potential but failing is a common FSU trait unfortunately , best described as "when there good there very good :cool: when there bad there f*@%^$ awful " :bang:
:D Paul
keep in mind that you ARE buying cameras that someone else decided they could live without. Very often, there's a reason they could live without it. It could have worked flawlessly for 30 years, then it started acting erratic, and up for sale it went. That's why I usually feel it is smarter to pay "too much" for a used item than to try to buy something dirt cheap.
I would suggest also checking the shutter blind track at the top and bottom of the film gate, little chips of film can lodge there. I tend to find that a blower just moves the dust to some other annoying place.
Get a length of clear plastic tubing , about 1/4 inch diameter, and a large rubber bung with a hole in it. You can often find this stuff in a store which sells kits for home brew beer!! Put the bung in the end of your Vacuum cleaner hose, with the clear plastic tube through it, then use it as a mini vac hose, and carefully and gently clean out all the nooks and crannies in the camera.
Unfortunately, my experience with that philosophy is that I end up with much more expensive junk.
Ideally, I'd like to buy all my stuff off of the members here...figuring they've already gone through the pain. Very little of that comes up though.
I may have a mini-vac at work. We'll see what tonight's blow and go does for me.
Well, nothing is helping. I blew, I cleaned, I lightly lubed....
1/30th is still bulb almost all the time. 1/60th stops halfway through sometimes and the curtain follows to quickly other times. Sometimes it works.
1/125 and 1/250th are good better than half the time. 1/500th is bad 90% of the time.
I'll be looking for someone domestically to cla the thing.
steve, if the other fed2 works well, why not fixing its RF? thats probably easier to do than a shutter. or what do you mean by iffy Rangefinder?
btw. did you use a 85mm VF with your Fed2-J9 combo? how did you get the VF in there? I am thinking of getting a Z-6 for J9, but wish I could use the Fed2.
Hi,Yuri at Fedka.com has a CLA for 60.00.Always hear good things about this service.He's in N.Y...........Robin
The rangefinder on the other fed2 seems reasonably accurate, but I can't get the vertical adjusted well to save my life. Along with the fact that it's really dirty in there, makes it tough to use.
I have a Nippon Kogaku viewfinder that I got off of the auction site for $55. It looks like this one. http://tinyurl.com/yhxenh
Thanks Robin,
I'm going to check a local guy first, he's (at least) semi-retired though and I'm not sure he'll do them. He learned his trade with the Navy in WWII, so I think we can understand if he doesn't take on much new work anymore.
I've done some additional playing with this thing and have more information. Perhaps someone will have another suggestion.
I did the ronsonol thing and that was no help. What I have noticed though that when I actuate the shutter by pulling down on the mechanism at the bottom of the shutter assembly INSTEAD of using the shutter button, the thing works right every time.
It's as though somehow the button is not coupled correctly to the release mechanism.
Does that help any?
Does that help any?
Hmm... if you look at the base of the film sprocket, you should see a little gear that is pushed down when you press the shutter release. Perhaps a touch of oil into where the shaft runs would be helpful.
