What's wrong with this Super Coolscan 5000 ED?
williaty
10:18 PM
This is a new-to-me LS-5000 that I'm trying to get up and running. Initial testing confirmed that it worked but showed very bad flare. I took it apart and cleaned the mirror. While I had it open, I took a quick peek at the very small amount of the lens that I could actually see and the lens looked pretty clean. The mirror was not as bad as I expected but also didn't fully clean. While all the obvious dust and dirt came off, the surface of the mirror still has a very slightly oxidized surface like I'm used to seeing on telescope mirrors that are >20 years old.
The result of the cleaning was an improvement, but didn't resolve the problem entirely. In the first picture, you can see a maximum capture area of a mounted slide. You can see the brighter areas in the image flare over into the area blocked by the slide mount. In the second image, you can see a closeup of one leaf of the main plant. The leaf has sort of an "echo" of itself.
Any idea what's causing this?
