Spyderman
Hi guys,
somewhere on this forum I read that someone has made this thing - a picture file that I could print on a sticker and put around the shutter speed selector. I have a Zorki 4 with printed shutter speeds, and they are slowly wearing off...
rbiemer
Unabashed Amateur
Spyderman,
It is this thread:
http://www.rangefinderforum.com/forums/showthread.php?t=20596
scroll down abit and there is a post with the image of the shutter speed scale.
that's "comp_wiz 101"s helpful work.
And welcome aboard!
Rob
It is this thread:
And welcome aboard!
Rob
comp_wiz101
Compulsive Tinkerer
Yep, you can find it there
. I had the same problem, obviously... The best post, however, with more info and a newer version (the one I ended up using) is on here:
Solution to worn Silkscreening
Bas
Dough!
Excellent work... can I know what kind of adhesive did you use to stick the paper image to the dial?
Thanks for the hard work!
Cheers
Bas.
Cheers
Bas.
comp_wiz101
Compulsive Tinkerer
Thanks! The adhesive... cheap dollar store type glue. It was called "Clear Glue" and was somewhat gooey. I would not recommend anything that is very watery, like normal super glue. Try to look for a glue that says it can bond metal and paper and is fairly thick. If you really get stuck, you can try epoxy.
Hamster
I have come across a sign/advertising making shop that have the kit to laser engrave on metal, for self adhesive nametags on office door etc. Perhaps when you find the the graphic file, you can fork out a little more to have it laser engraved, that would make it a much better permanenet solution.
comp_wiz101
Compulsive Tinkerer
