Which 35mm? Biogon or Nokton?
toksuede
7:12 PM
So I got my CV 40mm 1.4 and I don't like it.
Nothing to do with the performance of the lens (althought the bokeh is not to my taste), but everything to do with the frameline. Yes, I know that I can file it down, but I'm really bothered by the fact that I have to guess where the frame is by looking at the 35mm frameline.
Therefore I started my research and decided to get a 35mm. Did think about the 28mm, but at the end of the day for what I intend to do (shooting football), the 28mm is not what I'm looking for.
I've narrowed it down to these two:
-Biogoon 35mm f2.0
-Nokton 35mm f1.4
I briefly considered the Hexanon f2, but it's completely out of my league in terms of price.
What I'm looking for first and foremost is speed as most of the shots will be taken when the sun is not out. I would have liked to consider the 2.8 lenses, but losing one stop from 1.4 was my limit. Second of all sharpness in the middle. Third of all compactness, the reason bhind the exclusion of Nokton 1.2.
I will mainly be shooting BW and I don't mind if it's mid or high contrast. That could be fixed in post.
Any input/suggestion/mockery wil be very welcome.
Ryu
If you like the 40's signature get the 35 Nokton. That's what I did having similar problems as you with the 40mm framelines. Nothing can replace f1.4. The way I look at it: to shoot 400 ASA indoors you need f1.4.
Note that only the 35/2 UC Hexanon is very expensive. The 35/2 M-Hexanon is usually cheaper, in the same price category as the Biogon.
And if you DON'T like the 40's signature, you could get a 35 f/1.7 Ultron. It has a smooth look, even though it's plenty sharp. Not as small as the 35 Nokton, though (but smaller than the Biogon).
I have a nokton 35, and have been thinking about getting a biogon. I tested one a couple of weeks ago, and really like the lens. It is, however, pretty big when compared with the nokton, and has no focus tab which sucks.
http://www.flickr.com/photos/mnewhook/4053301524/
I had both, sold the Nokton and kept the Biogon.
Now I'm on the verge of selling the Biogon and keeping a UC-Hex...
Thanks for the responses.
From the information I have gathered, the only thing Nokton does better than the Ultron 1.7 is size. Sounds like Ultron is a better lens than the Nokton.
So assuming no one is really seriously pushing the Biogon over the Nokton / Ultron, it's safe to say I would be the happiest if I go for the Ultron 1.7 for quality and price?
Shooting football - with a rangefinder and a 35mm lens?:eek:....would it not be a whole lot better/easier to use a SLR, and have the option of lenses that will get you among the action - when needed?
Dave.
PS.......bokeh is the least of my concerns - when shooting football!
I sold my 35 Summicron because my Summilux was a stop faster and I can't be arsed to go around changing 35mm lenses for quality vs. speed. If the picture is any good, no-one gives a toss about the extra quality of the Summicron anyway.
On the other hand I prefer the Summilux to the Nokton (which I had for a few weeks) because the Summilux is smaller.
Take what you want, and pay for it, saieth the Lord.
Well, I do shoot football professionally and I use 2 x D3s + big lens for that. But since I get bored very easily, I decided that from now on I'm going to shoot at least half a roll of BW every match so that I will have a series of football related photos. You can have a look at my flickr in my sig and you'll get the idea.
I did shoot couple of frames with the 40 1.4 and I'm getting an idea when and how I should use the ZI instead of the D3. (Answer: Not when they are playing)
And as Andre said, the Ultron is faster by .3.
And I agree with Roger's sentiment that good photos are good photos regardless of the lens. :)
I had both the Ultron 35mm f1.7 and the Biogon 35mm f2.0
I loved the Biogon... And it has very good corner to corner sharpness. Here is a free article by Sean Reid on Luminous Landscape, talks about both Ultron and Biogon.
http://www.luminous-landscape.com/reviews/lenses/fastlensreview.shtml
I originally bought the Ultron due to cost and then traded it to get the Biogon later on.
Edit: Both are wonderful lenses though.
EDIT X2: My first M lens was the 40mm Nokton. Used it until I got the Ultron, which I liked better. I would say go with the Ultron, you gain some speed over the Biogon and it is only 1/2 stop slower that the Nokton.
Dear Roger,
you must be talking about the 35/1.2 Nokton. The 35/1.4 Nokton (A) and pre-asph Summilux (B) are about the same size, IMO. The asph Summilux (C) is much larger than both.
I find (A) and (B) quite similar, with the Nokton flaring less wide open.
Best,
Roland.
you indicate you value speed, center sharpness, and compactness.
the nokton betters the zeiss in speed and size, not sure on center sharpness. that's at least 2 out of 3 in favor the nokton.
so, nokton, right?
Pavel: Well, you used it both and you liked both. I know this sounds strange, but do you consider the Biogon to be a lot better (ie 3 times the price) than the Nokton? It's a stupid question, but if all things considered if one lens is visibly better than the other, I will pay that and be happy. But if not, I'd be happy to buy the cheaper one.
Roland: Wow, the 35 1.4 Nokton is as small as the 40 1.4 that I have. Do you know how much bigger the Biogon and the Ultron are compared to the Nokton 35 1.4?
In a perfect world, yes. And the more I read about the Nokton and it being compared to the Biogon, I don't really see that much of a difference. And let's face it, the Ultron is BIG compared to the Nokton...
so, nokton, right?
Hi Toksuede,
the 35/1.4 is almost identical in feel to the 40/1.4, and optically just a little smoother. But it is a very sharp lens even wide open.
The Ultron is just a little longer, but feels different. More like a pre-asph Summilux 50/1.4. No focus handle. The Biogon and Ultron are similar in size, I guess. Note that the Ultron has .9m min. focus, the Biogon and Nokton 0.7m.
Bottom line is this: if you want to shoot landscapes and architecture, the Ultron or Biogon are better (practically no distortion).
If you often shoot people, you want to use the lens for travel, in-doors, and with 400 ASA or so, the Nokton is a great solution. I suspect the Nokton is also better built than both Ultron and Biogon, lots of reports about "wobble" (loose focus helical) for those two lenses.
Check the flickr M-mount forum. You will find many pictures taken with all three lenses.
Here is a characteristic Nokton shot on Arista 100:
Roland.
And here is some camera porn to show you size:
I use it together with the 75/1.4 a much more expensive lens. But the two match very, very well.
It depends on what you can afford. Since I was able to afford the Biogon, I could justify the increase in price for the increase in performance. Was the increase in performance drastic? No. Is it worth 3x the price? Yes, unless it stresses your income, at which point it is no. If you compare the corner sharpness of the Biogon to the Ultron, there is a huge difference. The sharpness is also better than the 40mm Nokton, which has a closer fov. I've owned the 40mm Nokton not the 35mm though, so I am unsure how the 35mm Nokton compares to the Biogon. You stated in your post that sharpness is important, so thus I would recommend the Biogon. The ultron is not that big of a lens and is very easy to handle. I personally like a little weight to my lenses. You said that the Bokeh is not to your taste on the 40mm nokton, and if recall correctly, the 35mm Nokton has the same type of bokeh (gathered from reading this site). So, if cost is an issue and you want the higher speed, go Ultron (if you don't like Nokton bokeh) or the 35mm nokton. If sharpness is more important that speed, go with Biogon. I also like how the biogon draws. It was my all time favorite lens, my last lens to sell when I left the film world. Now that I am picking up a film Leica again, I am getting the 50mm Zeiss Sonnar instead of the 35mm biogon. I'd go with the biogon again if I wasn't sticking to a one lense system (35mm biogon pared with 75mm Heliar is a good combo in my opinion).
