Which back?
DannyTreacy
10:53 PM
Hi all,
I'm really liking the format of the instant film I get when used with the 127mm lens on the Universal Press.
If I want to achieve something as close to this with film am I right in thinking I should use the 6x7 backs?
Thanks.
I suggest to take a ruler and measure your instant prints. The 120 film will give you negs 56mm wide (usually, sometimes only 55mm) you can work out the ratio from there. Typically 6x7 negs range from 55x69mm to 56x72mm (Linhof cassette) depending on the camera type.
