Re: Which collapsible lens for a Contax/Kiev?
My thoughts: I see 2 aspects to your question: (1) Speed--do you really need f/2 or can you live w/f/2.8 or 3.5?; (2) Lens qualities--Tessar v. Sonnar.
(1) Only you can answer the 1st question. From the fact that you're even considering the Tessar, I'm guessing that you don't absolutely require f/2. However, if you're going to be shooting a lot in the f/2-f/4 range, I would recommend the Sonnar, as the Tessar doesn't really shine until f/8 or so, IMHO.
(2) Based on my experience w/multiple examples of both the collapsible Sonnar (uncoated & after-market coated) & the collapsible Tessars (both f/2.8 & 3.5, both uncoated & post-war coated), I would say the Tessar actually has smoother boke than the Sonnar, particularly noticeable when shooting @ the larger apertures & when you have a busy pattern or point light sources (e.g. Xmas tree lights) in the background. The f/2 Sonnars never give you the super-"swirly" backgrounds that the f/1.5 versions do, but they can get close. Starting @ f/8 or so, boke is less of an issue & all lenses are sharp, but I believe the Tessar is better corrected against diffraction problems, etc. @ the really small apertures (f/16, f/22), so it's probably a better choice for landscape-type work. Some practical considerations: the Tessar, even the heavier chrome version, is lighter in weight than the collapsible Sonnar, but that's not a big deal w/such small lenses. However, it's easier to use filters & hoods w/the Sonnar, as it has the 40.5mm thread.
Below are some sample shots. Not too illustrative, but they're all that I have readily on hand. The 1st is w/the Sonnar (uncoated, c.1936) @ f/2.8 on Tri-X & the 2nd is w/the f/3.5 Tessar (post-war coated c.1945, but shouldn't make a big difference here) @ f/4 on Plus-X.
wlewisiii said:
Seeing a place with a couple of sanely priced pre-war uncoated collapsables, I thought I'd see what which one the collective wisdom of the RFF believes I should get.
William
